Author Topic: D3.5 10.5 turn not liking one cell.  (Read 3662 times)
Offline BCbud
« on: September 07, 2013, 12:11:16 AM »
So I bought a D3.5 for my WGT car and I installed it with my older Tekin RS it cogged bad. I tried a different sensor board, same. I  tried a different Tekin, same. Then a sensor wire, same. Then I remembered a thread on RCtech about how to test the sensor wire voltage so I looked it up. I tested the speedo sensor voltage and it checked out ok at 4.8v. I took the motor out of the WGT and put it in my 1/10th buggy and it worked fine and the Trackstar motor that was in the buggy works fine in the WGT.
So why is the D3.5 not working? I am confused and frustrated.
Offline Shawn68z
Re: D3.5 10.5 turn not liking one cell.
« Reply #1 on: September 07, 2013, 03:38:52 PM »
Was the motor connected when you tested the voltage?    I am thinking maybe the open circuit voltage on the tekin might be fine, but when its putting out current it might be dropping...  Otherwise, are the settings in your onroad ESC the same as the offroad?
Offline Falcon
  • Safety First
« Reply #2 on: September 07, 2013, 05:44:37 PM »
That's what happens exactly. I went through this.
« Reply #3 on: September 07, 2013, 08:00:54 PM »
if it works in two cell and not single cell, maybe your booster is bad, or the tekin has developed a fault where the voltage sag is too much. if the voltage sags too low, it might cause the esc to go into sensorless mode as if the sensor wire was unplugged. id try a different booster, replacing or doubling up your esc caps, or even different batteries. 10.5 shouldn't draw enough to sag a 50-60c battery much in blinky.
otherwise, id send the motor back and try something else. there are an aweful lot of fast motors to choose that don't have all these issues with the tekin.
Offline BCbud
« Reply #4 on: September 07, 2013, 08:27:03 PM »
If there is a problem with the booster or Tekin then why would the other 10.5 work?
Offline Shawn68z
« Reply #5 on: September 07, 2013, 09:02:38 PM »
Most motors work fine with 3Volts on the sensor port.  The D3.5 switched sensor design/model, which REQUIRES 5V to operate correctly.  Out of curiosity, hook up the sensor board to the tekin, and then measure the voltage from the board. I think the current drop from the sensors are causing the problem.
Find a D2 sensor ring should do the trick, or send in the Tekins for the Gen2.   Or buy a hobbywing.
Offline Gorden
    • IROCC Racing Results
« Reply #6 on: September 07, 2013, 09:04:47 PM »
I have a sensor board you can try
