Found this on RC Tech. (
http://www.rctech.net/forum/6328770-post1527.html )
Front.
Caster: This is front grip. If you need more grip then move the upper arms forward. If its too much, move it back.
Reactive caster: This is where you want your grip. Going into the corner (10deg), even all the way threw the corner (5deg) or mid corner to exit (0deg).
Start with .018 front spring. If the traction is high or you have to dope heavy in front then .020's would probly be better.
Unless your having rear traction issues or your tires are WAY off then I would start with caster.
When you have that set, next is the side spring/shock spring combo. The two have a balance to each other where they work in side grip and forward grip evenly. That seems to be
Silver side/blue shock
blue side/gold shock... I would start here for stock/ss on carpet.
gold side/red shock.
A really good starting setting for the shocks is 30wt/30wt.
Set your side springs as soft as the lay out will let you. And by that I mean find the fastest, tightest direction change and see if the car goes threw it or if your waiting for the car to change direction. You shouldn't have to lift off the throttle for the car to change direction. Too stiff of a side spring and the steering will get twitchy right off center and it will start to throw the rear into the corner. This action starts to show up as double steer then gets worse. When I went from a gold side spring to a blue one, the car went a tenth faster. Then from the blue to silver it didn't get faster but it was more consistent. Any softer and I bet it would have slowed down. Pretty quick and easy to find the right side springs. Then fine tune the shock spring for the on-power steering you like.
There you go. Caster and side springs will get your chassis 90% there. Then fine tune the tires, aerodynamics and oils to finish it off.
