However, what is not so commonly known is...
If you take your United Federations phazer Mark IV, and set it's power output to level 9.8 with the flux capacitor set to 50fc's and point it directly at the dilithium crystals, then while holding a steady beam for approximately 1 minute and 16 seconds you would reach maximum recharge capacity for the dilithium crystals, of course not forgetting to continually rotate the dilithium crystals while concentrating your beam on the lower 1/3 of the crystal cluster so as to ensure maximum saturation of your beam.
This would then offer the absolute best arrangement for power supply to the entire IROCC Club, giving each member potentially unlimited options for drawing whatever current was required to meet each induviduals needs.
Of course the use of dilithium crystals has really taken off in Europe and is just now slowly making it's way to us backward folk here in North America. One of the many well know advantages of course is that when running your charger at 13.8 or even 12 volts while charging a 4-cell pack, there is almost no detectable heat thus expanding the life span of your cells and allowing users double or triple the voltage on their chargers and charging at upto three times the normal 6 amps with your 3300's.
There's no longer a need to lower the input voltage by dropping the output of the power supply, or even using a dropping resistor to help keep your charger cool. That's just one of the many nice features about using the dilithium crystals.
Of course we would need to make sure we had enough of the ST-K9 leads and adaptors for all the members in the club.
