Upgrade your Xray NT1 to 2009 specification with this conversion kit. The complete set of new parts will will bring your car to the new 2009-spec specification by improving fine details to increase reliability and performance. Your 2009 NT1 will be able to put you into the winners circle at a club, national, or world championship level with all the finest features that put Chief Designer Martin Hudy himself on the podium at the 2008 World Championships. Bring home victory with the 2009 NT1, the best of the best.
New 2009 NT1 Specs:
- included optional XRAY aluminum racing shock bodies
- included optional HUDY Spring Steel front & rear CVD driveshafts
- new wider 2-speed 2nd gear for increased durability & lifespan
- new reinforced & improved suspension parts
- new wider central drive belt for increased durability & lifespan
- new fuel tank pressure cap with 1-pc profiled seal for perfect fitment
- new steering servo mount for mid size servos
- new top deck mounts for mid size servos
- new belt tensioner holder for improved belt tension adjustment
- new updated radio plate
- new harder 2-speed springs
Full Conversion kit Parts list:
308305 XRAY Alu Shock Absorber-Set 4-Step x 2 Pcs
332110 Composite Suspension Arm Front Lower - V2 x 2 Pcs
332130 Composite Suspension Arm Front Upper - V2 x 2 Pcs
332210 Composite Steering Block Right - V2 x 1 Pc
332220 Composite Steering Block Left - V2 x 1 Pc
333070 Belt Tensioner Set - V2 x 1 Pc
333110 Composite Suspension Arm Rear Lower - V2 x 2 Pcs
333310 Composite Upright Rear - V2 x 2 Pcs
335205 CVD Drive Shaft - Front - Set - Hudy Spring Steel x 2 Pcs
335305 CVD Drive Shaft - Rear - Set - Hudy Spring Steel x 2 Pcs
335441 PUR Reinforced Drive Belt Side 4.4 X 390 mm - V2 x 1 Pc
335554 Composite 2-Speed Gear 54T (2nd) - V2 x 1 Pc
335581 Spring C=7.8 For Gear Box - Medium - Silver x 1 Pc
336120 Composite Steering Servo Holder - Set - V2 x 1 Pc
336230 Composite Radio Plate Mounts (L+R) - V2 x 1 Pc
338601 Fuel Tank 75Cc - Set - V2 x 1 P
in stock if any one wants it
http://www.nexusracing.com/product_info.php?manufacturers_id=&products_id=2691-=light=-
