does anyone have a Hobbywing Program Box So I can use to setup my Justock Club Spec ESC ?Gorden
Quote from: Gorden on October 09, 2014, 11:28:09 PMdoes anyone have a Hobbywing Program Box So I can use to setup my Justock Club Spec ESC ?GordenI also have one gord. Both Cameron and I run that same ESC. Just let me know when you need it. Shawn.
+1 Shawn if possible. I still have to install it but I presume you can program it out of the car? Gerry gave me one I will bring but I have never tried it on the speed passion I have that we thought it may work with.
Sorry Shawn I should have been a bit more specific. The SP is already set up for blinky and doesn't need programming. I just need the new one done that I got from Blake. Thanks again
Quote from: rcshadow on October 10, 2014, 12:33:52 PMSorry Shawn I should have been a bit more specific. The SP is already set up for blinky and doesn't need programming. I just need the new one done that I got from Blake. Thanks againWhich is a juststock? No problem.
Quote from: Shawn68z on October 10, 2014, 06:29:56 PMQuote from: rcshadow on October 10, 2014, 12:33:52 PMSorry Shawn I should have been a bit more specific. The SP is already set up for blinky and doesn't need programming. I just need the new one done that I got from Blake. Thanks againWhich is a juststock? No problem.Yes, Glenn got a Justock. Shawn, can it be programmed in any way without the programmer box?Blake
