Author Topic: programming  (Read 1955 times)
Offline A.l.b.
programming
« on: June 30, 2014, 01:14:53 PM »
can a speed passion club race connect to a i pad? if not how do you program it?
Re: programming
« Reply #1 on: June 30, 2014, 03:02:27 PM »
You need to buy the reventon led/lcd program box, or program it by the beeps as per the manual. Only useful functions on it are punch and brake settings. If you baught a club car both are already set at their strongest. You could add a bit of drag brake but for stock all that does is make heat.
Offline A.l.b.
Re: programming
« Reply #2 on: June 30, 2014, 03:38:35 PM »
i got a s2 from blake and it is in blinky mode. when i looked at the manual it says that it can be tuned to produce a lot more power .i think i need a programming card or like you were saying
thanks valk  :)
Re: programming
« Reply #3 on: June 30, 2014, 04:00:05 PM »
The manual covers the range of reventon escs which can be modifed to make.more power. Stockclub race doesn't have any software functions to increase power output such as timing or boost advance.
You could drop in a faster motor down to 8.5 turns but that would put the esc at 100% of its duty cycle.
Its the perfect esc for 17.5 blinky racing being so simple yet reliable. If you wanted something with more adjustments, or to run modified you would want a reventon r or pro.
Offline A.l.b.
Re: programming
« Reply #4 on: June 30, 2014, 04:40:10 PM »
ya that sounds good this esc is good for this season of racing i plan on still racing with the novice class and than i might move up.
Re: programming
« Reply #5 on: June 30, 2014, 05:02:55 PM »
I'm running that esc in my touring car pretty happy with it =]
Offline A.l.b.
Re: programming
« Reply #6 on: June 30, 2014, 09:13:43 PM »
it is a good esc  ;D
