Author Topic: Require a Rear, Rear Suspension hanger. Serpent 733.  (Read 2450 times)
Offline Shawn68z
« on: August 05, 2014, 12:50:36 PM »
If anyone has one I could beg, borrow, steal from them, I need one for this weekend, or my nitro  car wont be running.   I will return or replace it after the weekend, based on your preference.
http://www.serpent.com/product/804128/
Craig: I am going to swing by with the old one, and hopefully you have better luck withit.. I cant find my reverse drill bit, and the screw has snapped flush.
Offline Blake
  • Administrator
Re: Require a Rear, Rear Suspension hanger. Serpent 733.
« Reply #1 on: August 05, 2014, 04:38:32 PM »
Possibly grind a slot and use a flat head screwdriver?
Offline Shawn68z
« Reply #2 on: August 05, 2014, 07:31:45 PM »
Tried, and the two "sides" of the screw gave out.. think this one might be a write-off.   I will let craig have a shot at it, he has had better success removing screws then I have had.  If not, then I will  give JohnB a call and see if I can borrow one from his car.. there has to be one in Victoria somewhere!
Shawn.\
« Reply #3 on: August 05, 2014, 07:44:55 PM »
rob and gerry have 733's and failing all that, ill bet eddie has one. you should be good.
Offline gotnitro
« Reply #4 on: August 05, 2014, 08:10:40 PM »
I can take the one off my car if you need it shawn I don't think I have spares for that but its your if you need
Offline Shawn68z
« Reply #5 on: August 05, 2014, 08:27:23 PM »
Thanks Gerry.  I will send you a PM in the next day or so If I need it..
Cheers,
Offline fasteddie d
  • Forum Rookie
« Reply #6 on: August 06, 2014, 10:57:45 AM »
I have one .. Get your a## over hear . :D
Offline Shawn68z
« Reply #7 on: August 07, 2014, 04:41:56 PM »
Thanks everyone,  Craig definately has better success at getting broken screws out of parts, and has saved the day again!  Thanks Craig!
