Author Topic: Fall Racing 2021  (Read 506 times)
Offline Blake
  • Administrator
Fall Racing 2021
« on: September 08, 2021, 06:10:10 PM »
IROCC Fall 2021 Race Season Information:
Welcome to IROCC's Fall 2021 Carpet Season.
Dates in 2021 (Saturday evenings):
Oct 9
Oct 23
Nov 6
* Nov 20 (cancelled by Eagle Ridge) *
Dec 4
Dec 18
Jan 1
... remaining 2022 dates TBA
Eagle Ridge Community Center Dry Arena
1089 Langford Pkwy, Victoria, BC V9B 0A5
Race Night Program:
4:00PM Doors open for track setup
4:45PM Practice
5:15PM Q1
6:25PM Q2
7:35PM Q3
8:45PM Mains
10:00PM Track teardown
Race Classes:
Touring Stock 21.5
12th Scale Stock 17.5
Novice
Race Fees:
Adult $30 flat fee
Child/Student $10 flat fee
Track:
100' x 48' CRC Black Carpet
Notes:
The building is very large with lots of room to spread out
Tables provided
Chairs NOT provided
Bring an extension cord
« Last Edit: October 07, 2021, 01:26:27 AM by Blake »
Offline Blake
  • Administrator
Re: Fall Racing 2021
« Reply #1 on: October 01, 2021, 06:15:12 PM »
Fall 2021 Carpet Racing Updates
We are one week away from our first carpet race of the season on October 9th.  Please read the following updates:
  • Covid Protocols: As per Eagle Ridge and the PHO, masks are mandatory at all times inside the building unless eating/drinking.  Vaccination passports are not required unless we have more than 50 attendees.  Last Fall we averaged between 20 and 40 attendees.
  • First Race Night: Please arrive by 3:30PM on the first race night.  We will hold a driver's meeting before going inside, and we need help prepping the track equipment.  The first race will feature extended practice time, followed by two qualifiers and one main.  Future race nights will run three qualifiers and one main.
  • Tables/Chairs: Eagle Ridge has some tables for our use, but not enough for everyone.  If you have a small table, it would be wise to bring it along.  You MUST bring your own chair.
  • Payment: Cash and E-Transfers are accepted.  The E-Transfer email address is the same as last Fall.  Message me privately if you need this address.
  • TC Rubber Tires: The club will have touring car rubber tires on hand for purchase.  They are the same tire that most racers used last Fall.  These tires are not mandatory, but they are a good choice.
  • Traction Compound: SXT is the only permitted traction compound.
« Last Edit: October 01, 2021, 06:30:55 PM by Blake »
Offline Blake
  • Administrator
« Reply #2 on: October 06, 2021, 07:08:30 PM »
Important Quick Tips for Race #1
Follow these tips if you want to have fun at Race #1.  The car must be race ready, with the battery installed, before making these measurements:
Touring Car
12th Scale Car
  • Ride height should be set somewhere between 3.2mm and 3.6mm.
  • Body height should be set to 8mm.
Front Tires
  • Same applies to 12th Scale front tires.
« Last Edit: October 06, 2021, 07:18:06 PM by Blake »
Offline Blake
  • Administrator
« Reply #3 on: October 07, 2021, 02:52:12 PM »
The CA Accelerator/Kicker used in the above tire gluing video is optional.  If you don't have any, just let the glue air dry.
I will have some Accelerator at the track on the first race night.
Offline Blake
  • Administrator
« Reply #4 on: October 10, 2021, 07:33:38 PM »
Awesome First Carpet Race!
Thanks to everyone who made it out for our first carpet race of the season yesterday.  Track setup was super smooth, especially considering we built a new layout.  Setup will be even quicker at the next race now that the layout is chalked.
We saw lots of great racing, and also some first-race car setup issues.  Get your cars sorted as the next race will mark the start of a friendly four-race points series taking us to the end of December (one throw away).
Big thanks to Terry Yeo for making the trip from the Lower Mainland!  It was great to see him racing with us.
Next Race is Saturday, Oct 23
Driver's meeting outside at 3:45PM, doors open at 4:00PM.
Results
https://drive.google.com/drive/folders/12BzpmfWSUsTO_3HacbsumVtOD3lSVteG
« Last Edit: October 10, 2021, 07:37:36 PM by Blake »
Offline Blake
  • Administrator
« Reply #5 on: October 14, 2021, 07:32:38 PM »
12th Scale Tips
With some new racers entering the 12th Scale class, I figured it would be smart to post some videos about basic setup and maintenance.  These videos are a bit old, but they contain some really good information:
Chassis Tweak and Pivot Ball
Watch the first five mins:
https://www.youtube.com/watch?v=-ct2L3KEkE0
For the pivot ball, instead of disassembling anything, a shortcut is to loosen the rear pivot, hold the car by the rear pod with the car pointing down at the ground.  Then shake the car around to let things settle, and gently retighten the pivot ball.
Ride Height, Droop, Tweak
First five minutes:
https://www.youtube.com/watch?v=gq00eXAkwOo
(aim for 3.6mm ride height for our track)
Check Front Suspension and Rear Tires
Second half of video:
Differential
Does not apply if you're using a spool rear axle.
https://www.youtube.com/watch?v=bIYBed6VmNw
12th Scale at the Highest Level
https://www.youtube.com/watch?v=NWI6v-4egh4
« Last Edit: October 14, 2021, 07:45:34 PM by Blake »
Offline BCbud
« Reply #6 on: October 19, 2021, 02:29:33 PM »
I have looked here and on FB and I could not find out if we run the spec 1/2th scale tire or is it open?
Thanks, Neil.
Offline Blake
  • Administrator
« Reply #7 on: October 19, 2021, 05:42:46 PM »
Thanks, Neil.
Hi Neil,
Technically it's open, but the spec purple stripe tire is preferred.
Offline Blake
  • Administrator
« Reply #8 on: October 19, 2021, 05:58:28 PM »
Club racing this Saturday October 23rd
This Saturday evening is our next club race.  Doors open at 4:00pm and track setup starts at 4:10pm.  All local racers are expected to help with track setup (reasonable exceptions are fine).
Registration and a quick drivers meeting will take place outside at 3:45pm, before we enter the building.
We will run a full race program with three qualifiers followed by the mains.
This race marks the start of a short 4-race points series (one throw out) taking us to the end of December.
See you there!
Offline Blake
  • Administrator
« Reply #9 on: October 24, 2021, 06:44:43 PM »
Another Fun Club Race!
Thanks to everyone who attended last night's club race.  We had another great turnout and lots of fun racing.  Big thanks to Terry and Jesse for making the trip from the Lower Mainland.
Shout out to Jarrod for taking the TQ in 12th Scale in his first race in 12 months.
More shout outs to Wyatt and Jay who were running 12th Scale for the first time and did very well!
Next Race is Saturday, Nov 6
Results
« Last Edit: October 24, 2021, 07:00:42 PM by Blake »
