Does anyone know where I can find one of these? Either a new steering or the foammy stuff to cover the steering wheel. I have looked everywhere.
Thanks
No worries. I have found some on ebay and horizon hobby. Thanks.
Although it takes some time to get used to, a larger diameter wheel will afford better control. I reccommend the Kimbrough knobbed wheel replacement (if they still make 'em). This is what both Blake and I use.
Tom, I looked for the brand but I don't think that Kimbrough makes them anymore. All they make now is spur gears.
Hmmm. Have you checked out:
http://www.kimbrough-products.com/access.htm?
Quote from: "SgRddY"Does anyone know where I can find one of these? Either a new steering or the foammy stuff to cover the steering wheel. I have looked everywhere.
Thanks
If you are in need of help right away I once used a foam tire from a 12th scale car as a "quick fix". Just slap a little sho goo in there. :wink:
Quote from: "Tom"Hmmm. Have you checked out:
Oh WOW.... look at that. That grip is something else. Too bad I've just ordered a new steering wheel. But I will keep that in mind. Thanks Tom.
And JP, that is a good trick also. Thanks for the tips.
