Racing Topics => Nitro Racing => Topic started by: BCbud on August 07, 2015, 12:11:43 AM
Title: Nitro motor after 2 enduros
Post by: BCbud on August 07, 2015, 12:11:43 AM
Well my motor did not do well in the 2nd enduro. After taking it apart the cylinder and piston are scored and there is some debris on the top of the piston and on the cylinder head. So I am going to give it a complete overhaul with bearings, piston and sleeve, con rod and wrist pin. I hope this will last a while only needing a couple of con rods to keep it going. This means I will not be running nitro for a while. :-[ :'( :-\
Title: Re: Nitro motor after 2 enduros
Post by: Blake on August 07, 2015, 12:59:12 AM
Quote from: BCbud on August 07, 2015, 12:11:43 AM
Hey Neil,
I've got a spare you can use for the remaining races this summer if you want.  I know you're not around this Sunday, but I'll bring it the following Sunday and we can get it setup in your car.
PS.  It may be cheaper to buy a new motor than replace the P/S/R, bearings, and wrist pin.  I'm not sure about OS parts, but my statement is definitely true for Novarossi parts.
Post by: BCbud on August 12, 2015, 09:01:15 PM
Quote from: Blake on August 07, 2015, 12:59:12 AM
Hey Neil,
Thanks for the offer Blake but I think I will let the nitro car rest until the parts arrive. I had the bearings, rod and pin so it was buy the sleeve and piston or let these parts go unused or sell them.
Post by: valk on August 13, 2015, 12:18:25 PM
If you have any extra bearings ect you want to sell I'd be interested. I had a new front bearing but really need a rear one.
If you had an extra rod that would be awesome too.
Post by: BCbud on August 14, 2015, 10:46:48 PM
Quote from: valk on August 13, 2015, 12:18:25 PM
Nothing to sell as I am rebuilding the motor and will be keeping the parts I have.
Post by: BCbud on August 20, 2015, 12:54:18 AM
Well I just finished rebuilding the motor, the rear (big) bearing was shot. I now have a better understanding of the motor clutch witch is good. Once it is back in the car and I do the shocks it will be  break in time.
PS: What was the name of the bearing company that was talked about last Sunday?
Post by: Blake on August 20, 2015, 02:16:59 AM
Hi Neil,
We were talking about Boca Bearings:  http://www.bocabearings.com/
Post by: BCbud on August 21, 2015, 10:32:29 PM
First start up on rebuild tonight.
https://www.youtube.com/watch?v=QuoKNZjr8_U
Tomorrow night the shocks and then brake in. I will need some help with the gear mesh on Sunday as I just can not seam to get it wright.
Post by: BCbud on September 02, 2015, 09:48:25 PM
So what is the general rule for braking in a motor? The instruction manual procedure says to set it to initial settings then run it for a tank then lean it out 15* and run another tank through it and keep on doing this for about two litres. That sounds like a lot to me, can I get some input on this? I have about 5 tanks through it and have leaned it out two times so far, varying the throttle with only short full throttle bursts on occasion to clear it out.
Thanks, Neil.
Post by: Blake on September 03, 2015, 02:08:25 PM
Hey Neil,
There are as many opinions on motor breakin as there are people.  Start here and follow some of the links:
http://www.rctech.net/forum/nitro-road/855730-best-way-break-new-motor.html
Personally, I am scared of the process, don't fully understand it, and don't have the patience for it.  This is why I've been buying my motors from a company that will break the motor in for me.  It does cost a little extra but it is offset by my savings in stress, time, and fuel.
