The HUDY Ultimate Engine Tool Kit was developed for serious nitro racers that want to perform critical maintenance on their nitro engines. The set consists of one tool for pulling out the rear engine bearing, and another tool that will press out the front engine bearing and also install both front & rear engine bearings. These tools allow you to easily and effectively remove and install both front and rear engine bearings. The universal components have been designed to work with either .12 or.21 engines with the use of optional bushings and collets that are available for use with different-sized engines.
CNC Machined from HUDY Spring Steelâ„¢ and black-hardcoated 7075 T6 aluminum for unsurpassed lifespan and durability. The lightweight design and compact size, make this tool easy and comfortable to use.
part number HUD107050
$80.00
