NTC3 and Xray FK04 for sale
Started by gearhead, January 13, 2007, 10:25:27 PM
The NTC3:
Like new Novarossi RS12S1X, only half gallon through it, still tight, comes other half gallon.
Dual chamber rear exhaust pipe.
bulletproof 4 mm Aluminum aftermarket chassis
Aluminum swing rack and bearings
Aluminum front differential case
NIMH reciever pack
K-Factory super hard hinge pins, will not bend like stock.
3 shoe clutch with stiff springs and drilled shoes.
2 speed tranny 21/27 48/54 gearing
Comes with some jaco foams some new some not.
full spring kit.
No radio or steering servo.
comes with everything pictured.
$350
XRAY T1 FK '04:
BMI chassis
Strong factory tuned CO27 motor.
3 spare motors (need new armatures)
4 3800 club packs.
Novak GTS speed control
6 64 pitch Robinson aluminum pro pinions
2 sets of rubber
Just add a radio!
$300
Cody
HURSDAY RACEDAY WOOT WOOH
Bump.
Nitro car lowered to $300
Xray lowered to $250
I will throw in the Associated starter box with 4 stick packs with the nitro car as well as a hitec hs-625MG steering? servo. Needs repalcement gear set (on order at shaver shop).
NTC3 still for sale, minus Novarossi engine.
the car that came in third in practice #2 main.
All my parts, including AE.12 engine (needs crankshaft) Pull start block off plate, two speed, 3 or 4 flywheels, 4 mm chassis, aluminum front diff, aluminum swing rack, 2 side pipes, one rear pipe. Carbon radio tray, ver. 2 rear suspension, 1200 mah nimh reciever pack, aluminum shocks.
$150
