Require a Rear, Rear Suspension hanger. Serpent 733.
Started by Shawn68z, August 05, 2014, 12:50:36 PM
If anyone has one I could beg, borrow, steal from them, I need one for this weekend, or my nitro  car wont be running.   I will return or replace it after the weekend, based on your preference.
http://www.serpent.com/product/804128/
Craig: I am going to swing by with the old one, and hopefully you have better luck withit.. I cant find my reverse drill bit, and the screw has snapped flush.
Possibly grind a slot and use a flat head screwdriver?
Quote from: Blake on August 05, 2014, 04:38:32 PM
Tried, and the two "sides" of the screw gave out.. think this one might be a write-off.   I will let craig have a shot at it, he has had better success removing screws then I have had.  If not, then I will  give JohnB a call and see if I can borrow one from his car.. there has to be one in Victoria somewhere!
Shawn.\
rob and gerry have 733's and failing all that, ill bet eddie has one. you should be good.
I can take the one off my car if you need it shawn I don't think I have spares for that but its your if you need
Quote from: gotnitro on August 05, 2014, 08:10:40 PM
Thanks Gerry.  I will send you a PM in the next day or so If I need it..
Cheers,
fasteddie d
Thanks everyone,  Craig definately has better success at getting broken screws out of parts, and has saved the day again!  Thanks Craig!
