GenX10 Update
Started by haddow, April 05, 2008, 04:03:55 AM
From teamCRC.com
"Hi,
Thank you for your interest in the new Gen-X 10. The car is shaping up very well and we are very busy trying to wrap up the car and get the initial release shipped. Unfortunately, some small issues and the basic complexity of the Gen-X 10 have caused us to fall a bit behind on our early release date.
The Gen-X 10 is much more than a basic 1:10th pan car. The Gen-X 10 has so many available configurations; 4 and 6 cell NiMh, 7.4 lipo, stick packs, side-by-side cells, 200 and 235 mm widths, servo mounts for multiple servo manufacturers... it really has a lot of flexibility.
Another item that has caused a slight delay is CRC's new 1:10th Road Diff Hub. Most of the other manufacturers are using a 1:10 OVAL hub made from an OEM supplier as the diff hub on their Pro-10 Cars. This is a huge compromise. Why does CRC design a new hub for the Gen-X 10? In a word: balance. With today's brushless motors, there is simply no way to balance the rear pod AND stay under the 200 mm rear width without a specific hub made for the 200 mm Pro-10 cars.
When compared to brushed motors, the new brushless motors must move to the right to center the motor's weight in the car. When moving the motor to the right AND using an off-the-shelf oval hub, the car becomes too wide for the targeted 200 mm width specification. CRC keeps everything legal and balanced by ditching the OEM oval hub and manufacturing our own proprietary diff hub for these new Pro-10 cars. This allows CRC to move the brushless motor to the right AND still keep the car within the 200 mm width.
When retro fitting a brushed motor to CRC's pod, it is quite easy to balance the pod using motor spacers to move the smaller brushed motor to the left. However, with the other cars on the market, the reverse is not true as it is almost impossible to balance the motor pod area on a car designed around the old oval hub specs. The only way to do it is to add lead weight in an effort to balance their poorly designed pod. It didn't take too many staff meetings here at CRC to determine adding lead may not be the most effective way to balance the pod.
In addition to the pod being balanced, the Gen-X 10 chassis is also balanced. We believe that because the pod is articulated from the chassis, both components must be balanced. A balanced chassis and a balance pod, not just an overall balance but each component separately. With the Gen-X 10 chassis, the receiver and servo offset is to the right, with the brushless speedo to the left. For tiny receivers, the transponder can also be moved to the right. This results in a balance chassis portion of the race car.
Another great feature is the 235 mm wide conversion kit for the Gen-X 10. In Europe, Canada and some parts of the USA, these cars are run using the Pro-10 rules that allow a 235 mm width. Unlike some other Pro-10 manufactures who dictate to the racers which width they should run by making their car a 200 mm only, CRC allows the racer to make the choice by offering a 235 kit. And don't let the other guys fool you, a 235 mm car will eat up and spit out a 200 mm car under almost any racing condition. Wider, lower, lighter; those 3 aspects produce performance most every time.
With the 235 mm kit, you can run front widths from 214 mm to 232 mm and rear widths from 220 – 235 mm. This adjustability fits the Protoform 905B, P35 and most nitro GTP bodies made for 1:10th 235 mm nitro racing.
So, in summary, while the Gen-X 10 is delayed a bit, the car is truly worth the wait. A plethora of goodies come on the car; CRC's aluminum damper tubes, 2.5 mm pure carbon fiber chassis material, Pro diff with our exclusive diff hub, large-body threaded hard anodized center shock with adjustable height, red aluminum hardware, CRC 1:10th Pro-Strut Front end, its all good. I can tell you that we have seen many a cool car come through the shop here at CRC, but much like a hot blonde in a bikini, the prototype Gen-X 10 is attracting ALL the attention lately.
Thanks for your nice words and interest in the car"
Frank Calandra
Thats nice. Wheres the car !
