track repairs
Started by gotnitro, May 26, 2009, 03:27:05 PM
no i was doing this during work hours so i couldn't get to involved on this so if someone has the time. I have a saw and probably only need a blade with lots of teeth for smooth cuts, there is one around here somewhere...
i picked up a sheet of this stuff so if ant one has the fantettis # i would like to drop it off at there house and i can take the saw from work and we can cut it at the track Tuesday someone needs to bring a Genny that will run the table saw.....
freddie
Quote from: gotnitro on June 01, 2009, 06:04:25 PM
Thanks for taking the initiative on this Gerry!  Very much appreciated.
brian said he can cut it on his workshop saw friday. So i will drop it off fanttetti later tonight or sooner
All right we have 24 new plastic boards cut. Had to make a make shift table so dont expect them to be as good as brians cuts. But they are good to go, so bring your drills boys so they can be finished at the track.
Quote from: gotnitro on June 19, 2009, 02:48:54 PM
"pure awesomeness"!  Thanks for the hard work on this Gerry!
What size drill bit?
if some one can make some more brackets ill try cut some new walls when i have time. i have 2 side jobs on the go so im limited for time after work.
all those that own a drill ....bring it friday
charging mine now. bit size?
i think 9/16 was to small so 5/8 would be fine its got to big enough to clear the end of the square part of the bolt. What about brackets????
I'll bring mine and the box of bits
-=light=-
