My starter wouldn't roll back
Started by ultrakarin, August 10, 2005, 10:09:23 PM
ultrakarin
As I pulled it off, it wouldn't go back in  8O
I don't know how I can fix this problem.
Do I have to take the engin apart ?
well i would assume it would just be the  return spring under the pull start cover  i have broken my spring many times it is usually fairly simple to fixjust pull the pull start cover off  along with the pullstart assembly and re coil the spring
ultrakarin
Could I get some help in person ?
ultrakarin
Where when should we meet ?
Thanks sooooo much in advance
ultrakarin
OK i'll see you there then
what's your name ? Doug ?
Uh its MR Doug.... you see when you're that good they call you "Mr"
ultrakarin
Did you guys struggle alot when u guys started doing RC ?
It seems that I never got to run my car since I got it.
Its challenging enough to learn how to get around the track smoothly with a working electric car.  It gets really tricky when your car isn't running properly and to top it off with Nitro its even harder to drive than an electric.  Come out to the club and we will be happy to help you out as best we can - then you can have some fun!
Right you are Kurk! :wink:         bring out the car this sun and ill see if i can help  you  once you get it running i would suggest comming to the track tues  nights around 630 or 7 and practice...........once you get the car running right its alot easier to get good at driving........but with nitro keeping it running long enough to learn how to drive can be a challange
