FS: Batteries for offroad electric, etc..
Started by Grinder, December 29, 2005, 05:32:27 AM
I have way to much stuff kicking around - anyone need any coin doors or counters - finally throwing boxes of stuff out and there is no end in sight..  ;)
1100 mAH 7 cell 2/3A NiMH packs with Dean's ultra plugs
Perfect for RC18T, etc or build yourself a nice receiver pack.  $12 each or all three for $30
3000 mAh 7 cell sub C NiMH "hump" packs.  These are "no-name" brand although the performance specs are almost identical to GP3300 (had a graph somewhere comparing them to GP3300 at 30A load).  I believe these are relabled GP "seconds".  These cells will source 30A+ no problem.  I've been using them with the most demanding brushless set up with excellent results.  I just have too many packs and I may as well sell these while they are still in tip top shape rather than collecting dust.  The GP3700 just get more use....
Paid $65 for the loose cells per pack - asking $40 per pack assembled with Deans connector and 10 gauge wire, $70 per pair or all four for $120.  Perfect for bashing, etc - 7th cell adds a fair amount of extra ZIP to your setup!  Only about 15 runs on each pack - too busy to go bashing it seems....
Opps...  Sub C should read 3300 mAh not 3000 mAh....
roagracer
Hey Grinder, I would have to talk to my dad but I might be able to take a couple off your hands, finally got the rustler back up and working. Got any hight turn motors, above 15 kicking around, maybe we can make a deal.
ow the driver of the #77 ROSKO Racing IMS4 ministock race car. yes its fast, no you can't drive it
