electronics
Started by , March 14, 2006, 05:59:20 PM
just wondering if there is any reason  an ESC should not be mounted so it is touching the receiver?
The ESC, especially modern high-frequency ones (that is, ones made since the early '90's) are a source of radio interferance.  The proximity of the source of the interferance to your receiver will dictate the amount of problems it will cause; there is an inverse-square relationship (meaning if you double the distance, there is 1/4 the interferance).
So, the more distance you have between your receiver and everything else in your car electronic, the better, but I would be more concerned about keeping distance between your motor and your receiver than yuor speed controller and your receiver.
unfortunatly my receiver must touch the esc but it is a quantum 2(if that means anything) and the esc is between the motor and receiver and there is aprox 1/4inch between servo and receiver..................there just isnt any damn room in this T2.............hopefully there wont be any problems...........thanks for the info Tom
CHRIS_MORRISON
Quote from: "mrdoug"just wondering if there is any reason  an ESC should not be mounted so it is touching the receiver?
doug i run the esc and the reciever touching in my t2 and not had one single problem
ww.t-bang.ca (team driver)
www.powellracingcomponents.com
www.gqproduct.com
www.tqcells.com
www.dekelz.com
Hotbodies AH-12    X 2
I was so dialed, I was calling collect.
Just test it out - if it doesn't glitch you're laughing.  Try twisting the motor wires together - helps cancel the noise out...
