CRC Gen10X wide kit update
Started by Gorden, May 28, 2008, 07:52:20 PM
My reply from CRC
QuoteHello Gordon,
We received the samples today and they look very good. We have approved the samples with the machine shop, so production will start right away & we should have parts to send out around 6/11 – 6/13.
Thank You,
John Firsching
Calandra Racing Concepts, Inc.
Phn/Fax 315-338-0867
john@teamcrc.com
www.teamcrc.com
Maybe Craig can get them sooner
-=light=-
hey Gord, dont you have the pre-production kit?  Why would you not run it? I have installed it on my car and it works quite well, The rear tires dont wobble or vibrate at all.
Just take your time installing it.
I tried and no matter how slow I went the non drive wheel would wobble. any way these lola bodies work ok for now.
I had the same problem so I went back to the original set up just in the rear.
Quote from: "light"I tried and no matter how slow I went the non drive wheel would wobble. any way these lola bodies work ok for now.
Did you take a dremel tool to the inside of adapter that goes on the hub? You need to "soften" the edge of the adapter to make it fit straight and true.
I know mine worked way better when I put the missing screw back in.  ;)
