new serpent 733
Started by gotnitro, June 19, 2009, 02:13:03 AM
Quote from: gotnitro on August 07, 2009, 02:36:04 AM
85% done....looks good
strange, they made all the rear stuff out of aluminum but he front end is all plastic..lol
look closer there is lots of aluminum in the front
Gerry nice job are you racing it on sunday and can you bring it to jodys on sat.
john ;D ;D
wont be there this sunday and i may not be able to make jodys as well but might be able to show it off sunday for a while.
weird this car has no set up guides or tuning paper work like the 720 came with, it doesnt even tell you witch diff lube goes where. Just a manuel and stickers...That will all be in the 2010 upgrade 733 kit...lol
I found this here http://www.rctech.net/forum/nitro-road/303147-serpent-733-1-10-200mm-touring-52.html
QuoteSo regarding the setup, this is the one out of the box:
Front
stock diff oil
0 droop
middle roll center position
car long
2mm caster in front of arm
5.5mm ride height
stock springs (blue) 1st hole
3 hole piston
40wt oil (1000 cst)
0.5 toe out
1.5 camber
stock sway bar, flush in the collar
ackermann in back position and narrow
198mm width
Rear
stock diff oil
3 droop
1st hole bottom pins
car long
camber link inner and 2nd position from bottom
2mm under link on inner position
6mm of ride height
stock springs (red short) 2nd hole
3 hole piston
40wt oil (1000 cst)
2.5 toe in on each side
3.5 camber
stock sway bar, inside hole in the arm and flush in the collar
199mm width
Tires
38F
40R or 42R
2mm split
This will be my starting setup for the Nats:
Front
200K diff oil
-1 droop
car long
3mm caster in front of arm
5.5mm ride height
2 hole piston
1100cst
1 toe out
2 camber
stock sway bar, 2mm in the collar
198mm width
Rear
80K diff oil
3 droop
2nd hole bottom pins
car 1mm shorter
camber link inner and 1st position from bottom
6mm of ride height
Long pink spring 2nd hole
3 hole piston
40wt oil (1000 cst)
3.5 camber
Soft Sway bar inside hole in the arm and 2mm in the collar
199mm width
Tires
35F or 38F
40R or 42R
2mm split
hey where do i find the info for the recall on the gas tank
fuel tank aside it is still a kick ass car
send your order # and a picture of the tank and they will send you a new one. New ones will be out in around 10 days.
[attachment deleted by admin]
BigDawg
either i forgot how to count or it was alot longer than 10 days,you would think after soakin a guy that much for a car they would have been alot quicker,$500 paper weight without a gas tank
AKA MrDoug
Getting closer to pavement
