17T Pinion
Started by Shawn68z, March 29, 2011, 12:09:35 PM
Any have a 17T pinion I could borrow for a day or so. I am still having issues with my gear mess on my 720, and want to try a bigger pinion.
I may have an 18 t in my box I have to look and see what I have. I may have an old 17 t but will look after work
Hey I have a 17 with very little wear and a 23 and 22 that are new they will fit the 720
Quote from: gotnitro on March 29, 2011, 08:26:48 PM
Cool, if you could Pm your address and phone #, I will come pick the 17t up from you.   I think I actually found the problem today (but I have thought that 3 times now!)  But I still think the gear mesh would be better with a 17T. Want to know before I put in another order.
BigDawg
It should not matter what pinions your using as long as when you add the teeth on your first pinion and spur together they are no more than one off of when you add your second pinion and spur together
AKA MrDoug
They should be the same.
You can see why if you look here.
Quote from: BigDawg on April 05, 2011, 01:50:16 PM
Serpent has come out with a new clutch that uses new pinion gears.  The spurs will work, but the pinions only fit the 733 EVO.
BigDawg
Hmmm new clutch mabye I been outta the loop for too long the only new in the clutch I noticed in my 733 was the bearing size and assembly in the clutch bell. And yes Tom the same is ideal and best but it's very possible to be one off without any side effects.
AKA MrDoug
Got the 720 running tonight for about 2 minutes before blowing up first gear. Took some of the teeth randomly off.   Think this is the problem.
http://www.rc-area.co.uk/blog/2008/05/27/serpent-centax-3-wc-clutch-system/#more-3555
I have a limited selection of gears, and most of them are WC type of gears.. Time to buy either a new car, or atleast a new clutch system.   This effects all serpent cars prior to the 733 EVO.
