ride height
Started by littlealex, May 21, 2011, 02:07:53 PM
littlealex
any limit for ride height for wgt?
we run on pavement so if you scrape it wont hurt the ground. Not like carpet no limit on ride hieght
littlealex
thanks, whats average ride height do you guys set at?
The minimum ride height for WGT is 4mm, no matter what gotnitro says. These rules will be applied at Speedweekend. To protect my chassis from the pavement, I try to run 5mm ride height.
littlealex
go as low as you can go sparks are cool ;D
Hi all,
I wish I had seen this thread earlier.
There is no ground clearance rule for any of our outdoor classes.  You may run as close to the asphalt as you want.  ROAR's rulebook lists ground clearance rules for carpet surfaces only, and we'll follow this guide.
That said, you'll want to keep about a 4mm ground clearance to prevent damaging the underside of your chassis.
