How often do you clean/check your filter?
Started by valk, August 19, 2013, 01:31:07 AM
0 Members and 3 Guests are viewing this topic.
New nick name. For shawn.   The motor whisperer.  Lol.
Quote from: gotnitro on August 19, 2013, 06:10:10 PM
I got nothing better to do then sit on this website.. Had to go back to work today.. Sucks... Already looking forward to the weekend!
No metal bits though the back cover did get a little bit of marking from shimming the bearings. Very very light. Not enough to wear the coating on the crank even.
Ill try to seat the bearings a little closer together if its possible this time to eliminate that shim.
The problem was the clutch nut was compressing the bearings together which wore the front one out.
Which thread talked about head shimming? And my piston is convex with a dimple in the middle. Will that change the measurement? All my other engines were flat top.
More when i get home and have time to try to put it back together
The clutch nut was wearing out the bearing?  Did you use the cone from the engine?
I dunno that's pretty weird, the flywheel and clutchnut shouldn't be compressing the bearings at all. Just tighten the nut until its "tight", but don't torque the crap out of it. If it comes loose, put a dab of thread locker on it.
You going to have it running for tomorrow?
According to the motors manual.   The motor comes with .3mm shim (2 shims), and recommends breaking in with 20%, and then removing the .1mm shim (And continue to run 20%). Or leave the shim, and run 30%
There was no new Cone with this engine. just came with the manifold gaskets, some dust covers and a glow plug.
I think my shim on the crank might have pushed the crank just a tiny bit too far back. looks like it has made contact with the back cover a little. some light scoring on the back plate and conrod. but i cant imagine that getting into the bearings. there was black crap on the carb inlet after i pulled the filter assembly off.
most of the crap on the head button and piston im sure i can get off with a solvent and some scrubbing, but meh.
im sure this wil run just fine. i have a spare conrod and if i need a sleeve/piston its actually cheaper for this motor than my old TZ heh.
what page did it say that, manual in hand and head shimming isnt covered.. is there a better manual than the factory supplied one?
Motor insides looks good. Piston walls are fine.   Definitely no wear there. Looks like you did have alittle detonation at one time. Easy to do when the weather outside was really hot.
Head shims are discussed on Page 13. (Speed spec 2 manual),  Under "Dust Caps", it says "About the head gaskets.".  Page 10 & 20 talks about the recommended fuel being 20%.   OS Engines website actually recommends 20% Odonnel for this engine.
What fuel you been running? If its 30% then stick with it, otherwise pull the .1 shim out and run it that way.. You'll get more power.
#23
20% smurf piss. i might try that odonnel next year then. took the shim out and rebuilding.. ill probably clean and silicone the carb while its this far apart.
that info isnt in the spec3 manual.. weird.
Gesh.. That motor has enough rip on 20%, without the head shim (Providing it doesnt have premature detonation) will make even more power!
  I think for next year I might try and run some Kosmic fuel from DJ Appollo.  I spoke with him alittle this year about shipping, and we think we can get it done for a reasonable rate. I will have to make a trip to seattle to pick it up though. I will make a post in march if its going to happen.
I like it. But it seems to murder my transmission and stuff pretty good.
Replace my second spool insert for the season too. Maybe if im rich next year ill buy the xray Alloy spool =O
Quote from: valk on August 20, 2013, 11:20:24 AM
Or you could "ease" your way onto to the trottle...... Nahh... Never mind... Give'r and drive it like you stole it!
its entirely possible my clutch isn't set up perfect, but every week i have to take the shoe out and give it a sand or the clutch slips pretty bad and makes me chase other things. I might replace a few things and pass the car onto a would be nitro newbie next year as a roller. Id really like to start getting into some NIB cars. my spec r will be the first kit ive actually had the pleasure of tearing the bags open with.
Quote from: Shawn68z on August 20, 2013, 01:47:27 PM
Ease into it..? Forget that, drive it like it's a rental..
Quote from: jarrodH on August 20, 2013, 11:11:49 PM
..... drive it like it's a rental.....
Oh come on Jrod.. Everyone knows Rentals are only good for speed runs!  They never make it around the corner, with out hitting the curb!
