i need a part
Started by A.l.b., September 13, 2014, 03:40:51 AM
A.l.b.
does anyone have a ball bearing i can use in my pan car? it is a X-ray x12 and the part number is 941438.
Emaxx + parked car  don't mix..................
That is the diff hub bearring and it is the same as a CRC car and I have one you can have. There are 2 in this hub, is the other one ok?
A.l.b.
valk
did you get a new axle? you wont be able to glue that, the forces from clamping the dif prob wouldn't hold.
I included 3 tubes of bearings with the car
He should have the right parts on hand.
valk
was that a speed merc axle or xray? the threaded rod pulled right out of the axle. i kinda doubt that will work again.
A.l.b.
A.l.b.
Never mind there was a bottle of bearings in the bag I found them as soon as I put my glasses on!
Shawn68z
Quote from: valk on September 13, 2014, 03:27:00 PM
This is a pretty common thing to happen. And it can easily be glued with CA, or preferable a touch of Contact Cement.
A.l.b.
I used ca but did not touch any bearings
A.l.b.
And it tuns out that the bearings that came with it are slightly to small.
A.l.b.
I could not find the bearing that was the right size in the bag. He had silver bearings in there but the one I need is silver on the outside and blue on the inside.
Shawn68z
Quote from: A.l.b. on September 13, 2014, 04:55:55 PM
In the future. I would recommend having the axle removed from the car when working with CA Glue.  You should also spray the hole in the axle, and threaded rod with brake cleaner, or other solvent to make sure its clean before gluing.
A.l.b.
the ribbed shaft is fixed
Shawn68z
Quote from: A.l.b. on September 13, 2014, 07:29:52 PM
Wow... Easy there, their might be kids reading these forums!
