roll out
Started by gotnitro, October 21, 2009, 03:47:45 PM
hey what was the roll out for brushless last year. i have a 74 tooth spur and ordered a 35 36 37 pinion because a 29 tooth pinion wont reach the teeth.
It's very dependant on your motor timing (either on the motor endbell, or in the ESC).  I think somewhere around 75mm of rollout is a good starting point.
12th Scale Rollout in millimeters = (TireDiam x Pinion x 3.14) / Spur
Ex:  (46mm x 37t x 3.14) / 74t  = 72.2mm
... and it depends on 4-cell or 1s ...
so would a 1s car be lower, like a 65 or so??
Quote from: jarrodH on October 21, 2009, 11:16:16 PM
sory ment higher..like  78 or 80?
Yes, I think they gear 1s cars slightly higher (larger rollout, more millimeters) than 4-cell cars.  But I don't really know.
Keep an eye on your temps.
And don't go buying every single pinion gear just yet.  Wait until you know what you need.
Melbatoast
I learned my lesson in trusting a single post from RC Tech - "We are seeing our rollouts for 17.5 1-cell in the 95-105mm range, while 13.5 1-cell is in the 80-90mm range."
I started at 98mm and ran way, way too hot.  My car is also 70g overweight, but I still don't think it's realistic.  Ran into the same problem with touring car, the gearing info found on those forums is weird.
From a somewhat more trustworthy source: http://www.rcracechat.com/vb/showpost.php?p=381377&postcount=107
"In the USA, with the latest software, the 17.5 guys are on about 90mm/rev, and the 13.5 guys are about 70mm/rev   As a guide, for our usual 46mm daimeter rears, that's a gear set of 47/76 for 17.5, and 36/76 for 13.5!!"
I ran 44/78 for 85mm my other two races and seemed alright for speed and temps.
remember, alot of people run 1/12 on a way more open track.
85 seems to be the number so far. Craig, Blake and myself were running 85 or close to it.
Yeah, I was 47mm tire, 84t spur, 46t pinion, for a rollout of 81mm.  After the main, my motor temp was 135F.
My motor endbell was at 0 degrees timing, and I had 30 (MAX) degrees added via the Tekin speed control, and I had the Turbo Boost setting at 20 (MAX), with the minimum 0.5s delay.
