Xray NT1 receiver pack
Started by rcshadow, March 26, 2011, 07:18:46 PM
rcshadow
To all the NT1 drivers out there that are using a lipo for their battery where did you get them from. I have looked a bit at the life batteries but it seems I would need a new charger to charge them. So if I can get a lipo and a voltage regulator it would work fine and I could charge it. But when I look all over the web the sizes don't seem to want to fit exactly. Any help would be great. Thanks.
Quote from: rcshadow on March 26, 2011, 07:18:46 PM
Most newer (within the last 2 years) lipo charges can charge life cells. Even the $40 cheapie I bought off ebay can.
rcshadow
Hmmm interesting cause all the RC web sites and RCtech that i have read for the last week all say that a lipo or Li-ion charger is not recommended for charging a life cell. Kind of why I asked about a lipo from nt1 drivers to see what they use and where they got it from. The Ice charger that I have has been out for more than two years too so I don't think it would work properly. I guess I will keep looking for a lipo and a regulator I know I can charge that just gotta make some room for a regulator. Thanks
rcshadow
Is that what you use Gord? Cause I have measured the pack that is in my car
And the one on the web site seems longer which has been my problem all week lol. My  NiMh is 83.74 long and the the one in the add is 85 mm long. I know it makes the car lighter but do you have to use the optional battery plate for the battery to fit? Cause it looks great and the rest of the size is perfect even the Mah is right on. I suppose I could dremel the plate to get some extra room.
Hey Glen.
Lipo/Life Charger  5 Amps $17.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11668
Life Battery $4.00
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14466
If you want I will go in on a Hobby king order, as this Life battery will also fit in my 720.
rcshadow
Thanks Shawn
  The charger may work but not according to some of the reviews lol. But the battery won't fit in the xray and I am pretty sure the serpent one is a hump to go under and behind the fuel tank isn't it?  My sizes I got are 30.92 wide 83.74 long 17.44 high. I get to match one of the three it seems but not all three lol. Thanks again.
rcshadow
Hey Gord
Did you get the brass battery cover or did you modify the stock one for that. Cause again with the measurements it seems just a tad to high. But you have already used it with out issue?
Quote from: rcshadow on March 27, 2011, 12:23:42 AM
Hey Gord
I use both of these
336156 - NT1 Optional Brass Lipo Battery Plate
Part#: 336156
this is for my backup battery
336155 - NT1 Optional Graphite Battery Plate
Part#: 336155
Quote from: rcshadow on March 27, 2011, 12:19:41 AM
Thanks Shawn
That Life will fit the 720 with alittle modification.  You need to trim out the side of the battery cover, then there is lots of room.
