Constuction of CRC Xti
Started by dajracer, November 01, 2012, 09:05:15 PM
I had 2 problems during the construction of the new CRC car.
1- The top hole for the ride adjuster on the left side bulkhead was not threaded far enough.
    Luckily I had a tap the right size to thread it through all the way.
2- I could not get the bearing in to the ride adjuster on left side.
    I put a 3/8 drill bit through the hole, turned it by hand, to clean off some of the anodizing.
Other than these 2 problems, the build went fine and the car should be on the track Sat. night.
