pavement
Started by gotnitro, July 04, 2013, 01:47:26 PM
any tips,or same settings as we would do for carpet just thinking springs and tub lube?
rcshadow
Haha Gerry uses tub lube, is that with or without the rubber duck and little boats.  ::) :P
When I ran my 10.5 in this class I used the indoor setup except for ride height, you need 4mm to clear the parking lot lines and the bumps on the track. If you use a really soft tire you may want to start a little higher.
Neil
Yeah, I remember running my setup from indoor.  The only thing I changed was tires and body.  I used the highest downforce body I could find (Protoform AMR-12) along with Pink-rears and Magenta-fronts.  They last longer than GreyLow/Black.
