drifting
Started by limey, September 26, 2005, 01:40:54 PM
limey
hay
I made some drift wheels last night and cut a bunch of extra rings so if anyone wants a set of tires; post and I will make sure i bring enough on tuesday. all you need to do is glue them on to a set of old rims. I used 26mm wide rims and the pipe is cut at 1- 1/8 wide
see ya
ayne Racing
In loving memory of my sis
i'll take a set do you have any for 24mm rims
limey
i just checked and the ones i cut will work with 24mm and hang over aprox 1/16th on each side.
i will cut some to sit flush with the rim as well
ayne Racing
ill take a set please
ill take a set if you have any left
I've got a bunch I'll bring as well.  There should be enough for anyone that needs a set.  Just bring a set of old (or new) rims.  You can pretty much slide the wheels over the rims and put some CA around them and you are ready to run right away.  Craig's just friction fit so you may not even need CA...
I've got 22 cut and a few 5" pieces if we run out someone can cut their own.  First come first served.  I can probably find some more pipe if we do run out and need more....
limey
I've got 5 sets for 24mm rims and 2 sets for 26mm rims right now and I'll problery cut some more tomorrow so bring a set of old rims and lets get sideways :twisted:
ayne Racing
